Random Shutdowns When Battery Is Low
So I replaced my A1502 battery a couple of weeks ago and everything seems to be working smoothly. However, when the battery drains to about 4%, the machine abruptly shuts down. When I press the power button, instead of the laptop recognizing the battery is low and flashing the battery low symbol, it tries to boot and shuts down about halfway through the progress bar. This is a new problem for me. I have tried resetting the SMC, PRAM, and tried numerous battery calibrations. Is this intended behavior, or is my unit defective? Should I worry about battery health going forward?
Edit: added coconutBattery screenshot
Here is a screenshot of coconutBattery while charging from 0%
Update (06/14/2022)
Here is a screenshot after over 10 hours of uninterrupted continuous charge. Something to note is that the machine occasionally gets choppy on low battery which may be a power output thing.
Edit: screenshot from when throttling starts to occur.
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
由 Dan 完成的
After resetting the smc and PRAM, the current charge reading on coconutBattery changed from 99.9% to 98% while the system still displayed 100%. Keep in mind I’ve left it charging and left it on with a green light for 7 hours.
由 Troy 完成的
OK Good! Now disconnect the MagSafe and let it run down until it shuts off while being used. We want to find that point, and once it goes into sleep mode, you'll want to plug in the magSafe give it a minute or so and take another snapshot. Once we have that we should know what's up.
Now one piece of info we also need along with the battery cutoff is the time it took to get to that point and what was the running load using Activity Monitor to watch and capture the load and battery usage. Review this View energy consumption in Activity Monitor on Mac copy the graph and past it in as well
由 Dan 完成的
I usually only browse the web on it so the load isn’t high so I get anywhere from around 7 to 8 hours (although the os estimates there is around 9 hours).
由 Troy 完成的
@Troy - Thats about right, so I'm confused?? Your system then is working correctly. Your system will go into Sleep and then deep sleep when the battery gets low and that's about when it will happen.
The way you implied it was happening sooner, which would be a bad cell or the battery was not calibrated. Basically SMC needs to reset its high and low thresholds.
Resetting SMC clears them and running the system until it has gone into sleep sets the low bar and then the next charge fully (a full 15 hours) will set the high and doing it a second time. Any deviation of this will set it for that window and over time the window will increase from use as it learns.
Basically, the one time set or inching its way over multiple times of charge and discharge.
由 Dan 完成的
显示更多的11条评论
