跳转到主内容
加入维修社区 - 创建账户
iMac Pro,Apple 迄今为止性能最强的 iMac 。可选配置包括3.2 GHz 8核,3.0 GHz 10核,2.5 GHz 14核,2.3 GHz 18核 Xeon W 处理器。EMC 3144 / A1862 (ID iMacPro1,1)
Revert to Stand from VESA Mount
I am looking to sell my iMac Pro that was previously converted to VESA Mount. When I reattach the stand, I cannot get the hinge mechanism to "unlock" and go back to the original position inside the chassis.
Any suggestions on how to reengage the hinge so it can sit back inside the chassis? I feel like any attempts I make to pull or lift with the stand are going to break the assembly.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Thanks. I meant to log in and answer my own question. The only issue with using the tool to reengage the mechanism is that it needs to be bent at a 90 degree angle to catch it. Once I bent the plastic card I was able to get it to pop back in.
It's unbelievable that Apple doesn't include the instructions to disassemble the VESA mount in their 20 language manual.
这个答案有帮助吗?
得分 0
1条评论:
I'm trying to do this right now. Can you go into a little more detail? Did you bend it so that the card went up into the mac, or down?
完成的
添加一条评论
最有帮助的答案
I haven't done the iMac Pro, but I've done quite a few standard iMac's that have the same stand design. There is a small latch that you need to disengage using the tool that came in the kit or a credit card. Review this Apple manual for the iMac Pro VESA Mount to see where you need to slide it in.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris Mammarelli 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 53
总计 1,364
