跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
iPhone SE2 Home button stopped working after screen replacement
I recently performed a pretty standard screen replacement on an iPhone SE2. In case it's helpful, the screen was completely black with no visible signs of damage, but the phone booted up fine, other screens worked, and I could feel the vibration from the home button. When I actually went through with the repair, I obviously tested it before closing it up. The home button had stopped working with the "Could not activate Touch ID on this iPhone" notification shown as if the home button was disconnected or replaced. I then tested it again with the original screen and with two partially working iPhone 8 screens from prior repairs. The home button only worked with the original screen. I was unable to discover any information online about Apple locking down screen replacements on the SE2 like they had on the 13 (before they reverted it), but that seems like the only possible reason. Is this a known problem? Do you have any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
Known issue with replacement screens. The connection for the home button through the screens are utter garbage. Keep trying different screens. If the button works OK with the original screen then nothing wrong with the button. If you're buying specific se 2020 screens then try an iPhone 8 screen. They're the same. Or buy a genuine 'pulled' screen for more money. 7's, 8's and se 2's are a nightmare lately for garbage replacement screens coming out. Seems there's no quality control in China anymore.
这个答案有帮助吗?
得分 1
2条评论:
As I said, I tried two original iPhone 8 screens. The replacement was also a genuine refurbished LCD from a very popular and trusted seller (MobileSentrix). As a result, I find it unlikely that the screen was the problem. Still, thank you for the suggestion.
完成的
If you tried the original screen and the home button worked then the home button is not the issue. Check the frp connectors under magnification to see if anything is in it stopping the connection. I've fitted loads of iphone 8, se2 etc screens and not had one that required the original screen. Only had one where a pin in the frp connector was stuck in the plastic housing so it wasn't connecting. Once it was freed the button worked again.
完成的
添加一条评论
最有帮助的答案
Hi
It’s been a while since I did a iPhone screen replacement but I remember the iPhone 6S had this issue and it was solved by transferring the metal backplate from the display over as it had a paired Touch ID cable on it
As I said it has been a while but I would check that back plate for anything like that and if you see it swap it over to your new screen
Hopefully this helps
这个答案有帮助吗?
得分 1
2条评论:
It's built in to the backlight layer and merges with either the LCD or digitizer cable (I'm not quite sure which). It's not removable. Thank you fo the suggestion, though.
完成的
Your most welcome
Next I would try cleaning the connectors with isopropyl alcohol
完成的
添加一条评论
Screen problem or Finger print sensor problm
solution : change screen / change home fingur print sensor
If home fingure print sensor change can’t work fingure only Work doing home key
这个答案有帮助吗?
得分 0
1条评论:
I've tried four different screens, as stated in the post. The fingerprint sensor cannot be swapped because Apple prevents it, but it's definitely not broken because it still works with the original screen.
完成的
添加一条评论
The SE2 needs original parts from an SE2 iphone, having same issues and I broke my original iPhone SE2 home button when removing it ! Now I can’t record with my aux through th Dolby app I usually use 🥺
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben Simmons 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 104
总计 5,721
