跳转到主内容
苹果第四代智能手表,含可选的蜂窝连接支持,2018年9月21日发布。
125 个问题 查看全部
How to fix glass?
Hi.
I will attempt to change only glass of my apple watch 4.
I will fix it with loca uv glue.
But after that, can I use b7000 glue to fix glass to force touch? Because adhesive of force touch will not be efficient even with a new force touch.
Can I glue it?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Frankly, replacing the crystal is a very difficult job as removing the OLED panel which is extremely thin and fragile takes some serious skills! I would just replace the display assembly Apple Watch Series 4 Screen Replacement and you would use either Apple Watch (40 mm Series 4/5) Adhesive Strip or Apple Watch (44 mm Series 4/5) Adhesive Strip
As far as the ForceTouch a replacement would be better than trying to salvage it Apple Watch Series 4 Force Touch Gasket Replacement
Apple Watch (44 mm Series 4/5) Adhesive Strip图片
产品
$6.99
Apple Watch (40 mm Series 4/5) Adhesive Strip图片
产品
$6.99
Apple Watch Series 4 Force Touch Gasket图片
指南
难度:
困难
1 - 2 hours
Apple Watch Series 4 Screen图片
指南
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 0
2条评论:
I really appreciate you take the time to answer, thanks.
I know it will be hard but I am patient and often repair smartphones so I will try to do it.
If I broke the screen then I will buy a new one, BUT I have read that replacing the whole screen will made NFC not working anymore, so that's why I try before to replace only the glass.
I have seen a lot of replacement videos, in each of them they seems to glue the new glass to the force touch, I think it's because adhesive is not sufficient?
完成的
Well, not fully true!
You do need to do a bit of a brain transplant if you want NFC to work. The chip on the back side of the screen is the key! Carefully lifting the QR coded flex board will allow you to transfer the NFC over to the new display
完成的
添加一条评论
添加你的答案
zyssai 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 131
