跳转到主内容
Fiber and textile material that is worn for style, safety, and protection from the elements.
22 个问题 查看全部
How do I attach my Worn Wear patch
I received a worn wear patch in the mail, assumed it was iron on. After trying to iron it on I don’t think that is the case?? Should I sew it instead?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Thanks Juan! Turns out it is iron on. Just needs loads of pressure and two minutes each side. I might ask my boyfriend to help me sew it on more permanently… Not so sure yet
完成的
Sewing holds the edges down. Better, I"ve sewn lots of patches on uniform's the iron-on ones peel up over time. .
完成的
添加一条评论
1个答案
已选择的解决方案
Yes. Buuut... given that you needed to ask that you might want to get your mom, sister or girlfriend to do it for you, perhaps you could bribe them?. Seriously though, yes and you can do it yourself. Take the patch with you when you go looking for a needle and thread so you can match the color and hide your stitches. Straight pins will be useful to hold it in place while you sew it on. Happy learning! Note: You can get stuff that irons on, ask at the fabric store but sewing works better, or using both.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keiran Jack 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 185
