跳转到主内容
这台13寸的MacBook Pro使用四核英特尔十代i5/i7处理器和锐炬Plus核芯显卡,于2020年5月发布(型号为A2251/EMC3348,拥有4个雷雳3接口)
Left Fan at full speed even when computer is switched off
Hi community,
One day after a long storage time I switched on my MacBook Pro 13" 2020 (A2251) and the left fan was on at full blast all the time — even with the machine switched off. The fan (usually 8881 rpm) only switches off when the machine goes completely out of battery.
I tried SMC and PRAM reset to no avail, reinstalling the operating system didn't help, etc etc. I downloaded MacsFanControl but I can't reduce the speed or switch off the fan using the software (btw, right fan is ok, usually at 0 rpm—maybe to compensate—but can be controlled ok using MacsFanControl). The laptop just went out of warranty and I would like to avoid bringing it in for repair.
I am no expert but it feels like there must be some physical component (like a transistor) that has some issue. There was no water spillage whatsoever (not that I remember of at least), I just left the computer stored in a drawer inside its laptop case (protected from dust) for a few months while on parental leave. However, the computer was stored under a heavy pile of paper sheets (maybe 3-4 pounds). I'm unsure this could have caused the problem.
Could a fan replacement help? I am not convinced of this option because the fan is actually working, what is not working is the control of the fan speed. Any input is welcome!!
Thanks in advance you all,
sil
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Hi
Has the device been dropped?
It might be a dodgy connection for the fan!
It could be a verity of other things though
完成的
Hi,
No — it was a while ago, but I doubt I ever dropped it.
Do you suggest trying to open and connect/disconnect the fan first?
完成的
I would to that first before ordering a new fan
Also while you are in there I would check so see if they are dusty
完成的
Let run the onboard diagnostics to see what it tells us. Restart your system and press the D key to enter, let us know the error code/s it told you.
Reference: Mac startup key combinations
You might want to install this great app TG Pro. I find it offers a great view into your thermal system between the sensors and fan's.
完成的
Hi Dan,
I did run the diagnostics and—surprise surprise—Apple tells me "There may be an issue with the fan".
Below are the details:
Reference code: PPF003.
Additional reference code: PPF004.
Any more thoughts?
Thanks!!
完成的
添加一条评论
4个答案
已选择的解决方案
Hi
I would try disconnecting it and reconnecting it
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hi Sil
Yes, this does sound like a physical issue, because if you can still turn on your Mac, it sounds like a faulty component. Try getting a new fan first and see what happens.
Also, if you have been using it for a long time, a component might have over heated. I am not 100% sure, though.
这个答案有帮助吗?
得分 1
添加一条评论
@silsil Did you get your system wet? Corrosion damage on the logic board could be a cause or its time to replace the fan! MacBook Pro 13" (A2251, 2020) Left Fan
There is a feedback circuit which uses a tach to measure the fan's RPM's it could be damaged or the logic board speed control circuit has issues.
Replace a left fan compatible with a 2020 model A2251 MacBook Pro 13" laptop.图片
产品
$79.99
这个答案有帮助吗?
得分 1
添加一条评论
Update: I went to the local Apple Store and the person who helped me was able to solve the issue by just disconnecting and reconnecting fans and battery (and free of charge!). He said the connectors were securely in place, so maybe by unplugging the battery something got reset in the circuit (something that had not been fixed by SMC/PRAM reset). @hellomacos your original advice turned out to be the solution! Thanks you all :)
这个答案有帮助吗?
得分 1
1条评论:
THATS AMAZING!!!!!
Glad you got your Mac back on the road (or on a table or on your lap:-) )
If there anything else you need help with you know where we are!
完成的
添加一条评论
添加你的答案
sil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 69
总计 857
