跳转到主内容
Checking to see if Optical drive swap is possible
I'm looking to swap the SuperDrive from my PowerBook G4 Aluminum 12" 1.5 GHz for drive in my Model A1176 Mac Mini and vice versa. I'm just checking that these compatible? As far as I can see it looks like it.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
PowerBook's take a 12.7mm PATA Slot Load Optical drive.
The Mac Mini A1176 also uses at PATA 12.7mm drive..
no problem with a swap.
这个答案有帮助吗?
得分 1
3条评论:
Thanx for the clarification Matt., I was comparing hard drives instead of the optical drive.
完成的
Kind of weird that the Mini has a Sata drive but a Pata superdrive.
完成的
Sata Optical drives were slower to catch on. Apple Added them across the board Late 2008 - Early 2009
完成的
添加一条评论
添加你的答案
David Pagan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 1,014
