Printer will no longer fax
My printer will no longer fax or answer. Line to printer tests good. Everything else works perfectly with the printer. When is goes to fax I get a notice that "unable to send or receive faxes".
Hi @jimwsr ,
Try running the test fax setup from the printer control panel and check what it shows. See p.220 in the manual
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 245
2条评论
I plugged the cord from the wall into an old fashioned phone.
What do you mean,"is the scan and fax method on"/
由 James Wildgust, Sr. 完成的
@jimwsr I read that in a google search about your problem. I have no idea what that is, and if you don't maybe that is your problem.
由 bill 完成的
