跳转到主内容
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
Do I need to change wifi antenna assembly?
I replaced the battery and while opening up the screen, I tore off the wifi antennas from its assembly. However, the wifi still works after putting it back together.
The one thing I am confused about is, on this model, the antenna do not connect to anything on the motherboard, or am I mistaken?
There is a little metal piece on the bottom of the assembly (3rd pic) which connects to the motherboard but that piece does not attach to the antenna whatsoever.
I have attached some photos of what the antennas and the assembly look like in my case.
Thank You in Advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
I came to your same questions as I cannot find any contact surface for the supposed antennas. Anyway my antennas are a little damaged as the ones in the pictures of the guide as it's impossible to save them from scratching in the opening procedure.
Could you even find a replacement for this metal parts ?
完成的
添加一条评论
1个答案
The metal part is the connector; if you are close to the router you might have some functionality but it probably is pretty poor. I think yes, you need to replace them, there is some degree of protection built in but I wouldn't court on it being enough with no antennae attached, operating wifi without them may, (probably will) damage the internal circuitry. If it IS working at a distance from the router I will be very surprised and stymied too. Do you "have to" no, not if you never try to use the wifi. Good luck, and happy fixing!
这个答案有帮助吗?
得分 0
5条评论:
Thank you for the reply Juan!
The only thing is how does the metal piece and antenna connect together? There is no direct connection, that i can see.
完成的
See steps 23 through 25 in this guide it's hidden"
完成的
The pictures on this listing may be helpfull in figuring this out too, I'm NOT recommending the seller, shop around. The businesses section here may work for that too, this was just the best pictures I could find. Sorry for the slow reply, it was night here.
完成的
No problem Juan! Thanks for your help.
完成的
You are quite welcome.
完成的
添加一条评论
添加你的答案
Zafar Alam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 899
