跳转到主内容
加入维修社区 - 创建账户
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Is there a touch lcd controller board to repurpose screen?
I have this old, but in good condition iPad Mini. I also have a cracked screen Galaxy S8 that otherwise works fine. I'd like to reuse the touch display from the iPad Mini to create a DIY portable touch monitor that I can plug in this or future smartphones over USB Type C to basically have a smartphone powered tabled.
I've tried searching for controller boards for the LCD model from the teardown article (iPad Mini Wi-Fi Teardown), but to no success. Does anyone know if it's even possible to do this? Would it be possible to find one and ask the seller/manufacturer to put custom firmware on it? Being a Samsung display, I'm a bit surprised it's so hard to find, but it's also a very old device.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
It may be possible, but the dev and sample cost exceeds the value of the device many times over.
There are display controller debug boards for this model, but I don't think anyone has done any work of value to repurpose the touch panel.
这个答案有帮助吗?
得分 2
2条评论:
Thanks, I figured as much, just thought I'd ask. Thanks for all the quick feedback.
完成的
What board do you mean that supports the iPad mini?
完成的
添加一条评论
Hi
I don’t think you am an mod it to be a separate display but you might be able to get a app to do that
Iv used some apps with my 15 macbook pro and I works decently well
Hopefully this answers your questions
If not please ask
这个答案有帮助吗?
得分 1
2条评论:
I've seen that, but I'm looking to do something like this: https://www.youtube.com/watch?v=DrqdHVeB... and figured I already had a perfectly good screen to use for the project. Having a universal interface like USB Type C would be ideal to be able to use it for any compatible device.
完成的
I can’t see the video you sent me because it’s unavailable
Iv seen people do it with intel iMacs because
They aren’t as locked down as iOS devices
Is far as I know
Apple locks down iOS devices so that they aren’t easily modified
You may be able to try and find a extension board like what they use on iMacs but I don’t think it will be easy
完成的
添加一条评论
添加你的答案
T Cortina 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 63
总计 3,799
