跳转到主内容
Why is it still painfully slow after upgrading to SSD?
I recently bought a MacMini2014 from eBay. The stock hard drive was clicking and it was really slow so I swapped it out with an upgraded SSD. (Crucial MX500 1TB 2.5" SATA).
I used online recovery to instal MacOS - so there was no data or partition information carried over from the old stock drive.
It takes about 25 seconds before I see the Apple logo - and then a further minute before it fully boots up.
I feel like I’m missing something obvious here but all my searches thus far haven’t yielded a solution.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
New ssds are not compatible with older machines, I'm not a mac user but I assume you checked that? I saw a post here recently on the topic. Might figure in. https://www.crucial.com/compatible-upgra...)
完成的
Hi,
Thanks for taking the time to comment.
I checked as far as the SATA version (my Mac is SATA 3).
I have done some research and tried a few things like enabling TRIM support etc but had little luck.
Currently trying recovery option I’ve erased everything and trying clean install.
Worryingly - the time has jumped UP by 15 mins.
完成的
Hang in there, I expect a Mac person will turn up shortly.
完成的
hi
sorry to here you are having a problem with your Mac
I'm quite good with Macs so I will try my best to fix your issue!
lets start by downloading this https://apps.apple.com/gb/app/blackmagic... from the App Store
if you can run it and tell me the speed for read and write and we can work from there
完成的
Hey,
Thanks for replying. I missed the email notification, so just reacting now.
I actually downloaded the app right after I re-installed the OS. From memory I was getting around 380mb/s and 430mb/s which felt Ok to me.
I tried resetting PRAM/NVRAM I got the double chime so I’m confident it was done right.
I’m starting to wonder if it’s just a case of the CPU isn’t great (2 core i5) and it’s trying to run the latest MacOS and struggling.
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
Hi
From what your speed test result ad what you’ve already tried is telling me ,it sound like you have bad RAM
Not to worry though I would try reseating it and if no luck plug one stick in at a time and see if you can find out what one is bad through process of elimination
Hopefully this answers your question
If not, keep on going with the info!
这个答案有帮助吗?
得分 1
2条评论:
Sadly, the RAM in this model is soldered in. Is there a comprehensive tool that can check CPU/RAM and give off a report that I could upload?
完成的
Sadly as far as I know there isnt a app but there is a a command
If you power down your Mac and then on your keyboard press command D when powering back up
It will boot into a apple diognostic and should tell you what the issue is
完成的
添加一条评论
添加你的答案
Wayne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 584
