跳转到主内容
Introduced on August 23rd, 2007, the Nikon D300 is a 12.3 megapixel semi-professional DX format digital single lens reflex camera produced by Nikon Corporation.
17 个问题 查看全部
Why does the media card read full when there are no pictures stored?
The window reads 'Full' on my new media card.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Hi,
Have you checked the contents of the card when it is connected to a computer using a card reader to see what it on there?
完成的
Yes. It's a new card, but I checked it anyway.
完成的
@Conita Butts
Are there any files at all shown on the card when using a computer to view the card?
Check for hidden files as well.
They don't have to be pictures. Any data file type takes up storage space.
If there are no files but the card shows as "full" try reformatting the card using a computer (FAT32 format) and then check if it shows that there is space available on the card.
If still full it may be a faulty card.
What is the make, type and capacity of the card?
完成的
Will your camera format new media cards? If yes, try formatting using the camera software. If not, review your owner's manual or try Nikon online for tech support or find your model for info.
完成的
@jayeff Thanks for responding, @Jeff. I checked everything, plus it's a new card I purchased from Amazon. I had a photographer friend take a look at it. He used his card, and the same thing happened - the window on the camera read the card as full. It seems to be the camera acting up. I'm at my wit's end.
完成的
添加一条评论
1个答案
已选择的解决方案
@notbroken. I looked up my model on the Nikon website and found helpful information. However, I think I'll take it to a local camera store for them to check it out. I was hoping it would be a quick fix, but it isn't. It's okay. I'm still a little exasperated, but the camera shop should be able to fix it, at a minimal cost. Hopefully. Thank you very much for trying to help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Conita Butts 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 48
