跳转到主内容
The Acer Chromebook 11 C732 is a Chromebook computer sold by Acer and are a part of the Acer Chromebook 11 Series.
How can I safely remove hot glue from the keyboard
A device came across my desk with hot glue under the keys. My guess is that the user had attempted to replace the keys that had fallen off. How can I safely remove hot glue without damaging the key switches? I'm using 91% Rubbing Alcohol but I'm having little success.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
use the heat gun man its safer
这个答案有帮助吗?
得分 3
添加一条评论
Hi
This is a hard one but if you are careful,I have had success removing hot glue from delicate things using a soldering iron but you have to be really careful
Hopefully this helps
这个答案有帮助吗?
得分 2
2条评论:
Depending on how things go I might use this as a last resort. I'm gonna try using a heat gun on the lowest setting. Otherwise I want to see if there are any other methods.
完成的
Be very careful though using the hot air gun
Iv accidentally burned Apple Watch screens on their lowest setting with them
The reason why I said the soldering iron is because it’s much more controlled and isolated
完成的
添加一条评论
添加你的答案
Jacob Mehnert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 318
