跳转到主内容
The Lenovo ThinkPad S431 is a laptop with an aluminum exterior. It can be identified by looking for the model number "S431" on the right top corner of the keyboard. The ThinkPad is 0.8 inches thick and has a touch-enabled display.
Why my laptop is not opening
Why Laptop is not opening, i press a power button many times but didn't show anything
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi
Does the laptop show that it is charging when you connect the charger?
完成的
Yes, it is charging but the laptop is not opening
完成的
添加一条评论
1个答案
There are many reasons.
1.Short Circuit. Due to a short circuit, you maybe need to change your motherboard. Maybe only
2.Loose cables or disconnected. Note: a laptop won't work until you connect the fan
These are the reasons I could think of hope it helps you
BY AADHITHYA MATHAN
5TH STANDARD
CHAITANYA TECHNO SCHOOL
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sachin Goswami 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 143
