跳转到主内容
The OnePlus 7 Pro is an Android smartphone from OnePlus. It was released in May 2019.
39 个问题 查看全部
My back camera and front camera is not working
When we on it shows Balck screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
did u give camera permission
完成的
添加一条评论
4个答案
最有帮助的答案
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
I also have this problem. When I opened it, I found out that the front camera ribbon cable is cut. The front camera and the back camera uses the same board attachment. Since, I have been using this phone for almost 4 years. I bought another andriod phone other then fixing it. Hope this helps
这个答案有帮助吗?
得分 1
1条评论:
I have the same problem. At first only the front camera did not work but now both the cameras do not work, do you think it is a software problem or an hardware issue?
完成的
添加一条评论
Yes
The error is like the camera might be damageg contact customer care
这个答案有帮助吗?
得分 0
添加一条评论
Display repair madabeka
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neev Jain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 655
