跳转到主内容
Can I upgrade my SSD while having Monterey Installed?
I have bought an adapter, I know the process to upgrade my ssd. I have a USB that I will clone all of my Mac data onto, then ill install the new ssd and clone the data onto the new NVME drive. However will there be any OS blocks on my ssd and apple will not let me upgrade due to it being and aftermarket ssd. And should I downgrade back to Big Sur
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Cloning is no longer the way to do this as the OS structure is very different from what we had years ago.
The proper way is to use the migration process. First Step is prepping a bootable external drive using the OS installer for your current macOS release, I find a 32GB USB thumb drive is mote that enough for the task. Then backing up your stuff using TimeMachine to an external drive, remove the old SSD drive and slide in your new drive and using your prepped external drive boot up your system so you can prep your new drive using Disk Utility and then running the OS installer
Reference:
Then once your new drive is setup, launch Migration Assistant to recover your TimeMachine backup.
这个答案有帮助吗?
得分 2
2条评论:
Could I do the cloning on Big Sur or Catalina or High Sierra
完成的
@talhahneedshelp - You'll need to go back to OS-X Lion! It's not worth the headaches. I haven't needed it for the last 10 or so years for bootable drives. A data drive (one that only has my created work) I sometimes use it, but only on small SSD's, never on HDD's as one of the failings of cloning is it is block copy so any corruption is carried over unlike a file CRC copy. So what you give up for speed is corrupted/unstable files.
完成的
添加一条评论
添加你的答案
Talhah El-Fiky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 512
