How to remove the Keyboard/Touchpad connector board
I need to replace the topcase came with keyboard only, does someone know if it is easy and possible to remove the Daughterboard from the old case
Update (06/01/2022)
i am talking about this board
Can you explain a bit better, the top case keyboard doesn't have a daughter board as you can see here
Are you thinking of the trackpad?
@Sami Rahman - Thats the back of the trackpad
Here's the guide to replace the trackpad MacBook Air 13" Early 2020 Trackpad Replacement and if yours needs replacement here's the needed part MacBook Air 13" (A2179, Early 2020) Trackpad
Be careful here! the Early 2020 (Intel) is different from the M based Late 2020 model
The M series daughter board is glued to the uppercase using double sided tape which is quite tight. Using some Ethanol alcohol dripping a little around the boards edge should help is loosing it. You don't want to pry the board up with too much force as that will damage it. You appear to have found the board so it maybe easier to replace it.
这个答案有帮助吗?
I have finally done it during replacement of one liquid damaged top case. Beware of very strong black adhesive underneath and be extra careful while prying it to not bend it rendering it useless
Is there any tutorial about how to remove the keyboard connection board?
@eygjpefiy4yex2q - Its just glued down, but quite well! Using a solvent to help loosen the grip is all you need and patience lifting slowly.
I used a hairdryer from underneath and the wheel cutter they make for iMac screen tape. It was onerous. Here's hoping it works on the new topcase. I'm working on an A2179.
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 753
I am talking about the little board underneath keyboard as listed here https://www.aliexpress.com/item/10050019...
由 Sami Rahman 完成的
Ah! You picked the wrong system! You are looking for the newer M series which is different! I've altered the model identifier so its set for the late 2020 not the early 2020.
由 DanJ 完成的
Thanks, sorry for my negligence
由 Sami Rahman 完成的
