跳转到主内容
Repair documentation and information for the Google Pixel 4a 5G. Released on October 29th, 2020. Model number: G025E
33 个问题 查看全部
Front and Rear cameras broken. Fixable?
I am looking to purchase a used Pixel 4a 5g from ebay but it claims that the cameras have bad quality or does not open. What I would like to know is can this be fixed by simply replacing the cameras or is this a motherboard issue is some kind? I did some reading and claims that it is a defect but I can't 100% confirm this. Any thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You could try a hard reset which will wipe all data on the phone to hard reset the Google pixel 4a Press and hold the Power button. While you hold Power, press the Volume Up button and let go of both buttons quickly. Android Recovery options should be displayed. With the volume buttons, scroll to "Wipe data/factory reset" and press the Power button. If that doesn’t work replace the cameras it is very unlikely to be a motherboard issue
这个答案有帮助吗?
得分 0
1条评论:
I ended up purchasing a Pixel 4a 5G that has a line on the screen but is otherwise fully functional. Actually I managed to get the line to disappear by simply pressing in the bottom right area. Eventually I am planning to purchase a replacement screen and considering that parts are now available on ifixit that temptation is higher.
完成的
添加一条评论
添加你的答案
Dudefoxlive 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 57
