跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
Part of the LCD have bad pixels
Hi :-)
I have got a MacBook Pro 2017 13" mid 2017 model, since yesterday a stroke seems to be bad on the LCD screen. It seems to be more visible when the background is turning dark, I refer to the pictures underneath. (I closed the cookies pop-up in the picture)
When I close or open the MacBook in every position nothing changes.
I have reset the PRAM a few times, but does not help.
I have tried an external monitor, the screen is fine on the external.
I hope it will be a easy diagnose and fix.
Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It could be a hardware issue since it is not showing up on the external monitor, it has nothing to do with the graphics. Possibly something has damaged the screen and has caused it to do this. I don't know much about software, so I don't know if something there could be wrong.
这个答案有帮助吗?
得分 2
2条评论:
Yes, the displays T-CON board has a problem. Here's the needed part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and the guide to put it in 2016后期带Touch Bar的13寸MacBook Pro 显示屏组件更换
完成的
Thanks both. I'm not gonna fix it. Fingers crossed it will not be worse.
完成的
添加一条评论
添加你的答案
Peet 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 131
