跳转到主内容
一款任天堂为 Switch 系统生产的无线、经典的视频游戏手柄。型号:HAC-013。
My Nintendo switch pro controller won't charge or Turn on
After leaving my Pro Controller charging for more than an Hour it will not turn on or charge. Holding down the Sync button also does not work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Needs a new battery it seems like. Very easy to replace, all you need is a pretty tiny Phillips head screwdriver. Screw off the screws on the bottom of the black grips, then those 4 screws on the inside. You should be able to pop the backplate off and have access to the battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rasyid indrajaya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 368
