跳转到主内容
Laptops made by the Chinese company Huawei.
31 个问题 查看全部
Why my matebook d16 does not power on when I press the power on button
My Huawey matebook D16 power on an off button does not work, I can no power on my pc when I press the button, It only power on when I unplug and plug the battery and ass soon as I plug the charger it powers on rihht away without pressing the power on button, I did try all the seeting having not luck
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Is there something else someone can recommend or a trick kind a configuration, Bios, cmd etc etc, I did restore it to factory setting and the issue is still there
完成的
添加一条评论
2个答案
Try pressing the power button for 10 seconds then release. Then press the power button again to power on your computer.
-Warren-
这个答案有帮助吗?
得分 0
添加一条评论
Thanks, I did try that already and did not work I even tried with (Choose what the power button do) configuration and not lock.
这个答案有帮助吗?
得分 0
1条评论:
Hi Jesus.
I have the same problem with my lap.
Did you find the solution?
THX
完成的
添加一条评论
添加你的答案
Jesus 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 41
总计 1,531
