跳转到主内容
Vizio 42" LED TV released in September 2012.
45 个问题 查看全部
Loud pop no power / burnt board
I plugged in Vizeo TV and heard a loud pop. The TV now won’t power on. I opened the back up and discovered a burn mark on the back of the electric board, so I think I’ve identified the failed component but I’m out of my depth from there. Not sure what it is or how to replace it. It’s the black thing connected to the heat dissipator
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @newbie99
It is a bridge rectifier and it converts your 220V AC to DC voltage. You will need to desolder it form the board in order to change it.
You may also need to unscrew it from the heatsink to remove it completely.
The replacement is quite inexpensive. Just make sure you buy a similar rectifier with the same voltage tolerance. You should be able to search for it by the label on the component.
You should also check the fuse, in case it blew too!
Hope it helps!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Roberto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 21
