Why is my phone slows?
It runs slow how to fix
Hi @abudi78
Try the following and check if doing any improve performance.
这个答案有帮助吗?
There are a few reasons that a phone can slow down. Attempt a restart of the phone by pressing and holding the power button and the volume button on the side of the Samsung Galaxy A21s until the screen turns off. After turning it back on see if that helps the issue. Otherwise, it could be an issue with how much data is on the devices storage. See if you can unload some data and see if that helps the issue.
这个答案有帮助吗?
Try restarting the phone, and checking your phone's system health (you can do this by opening Settings>Battery and Device Care and performing the necessary actions for each category). This will also help you free up space with the help of the corresponding tab. Additionally you can also check for system updates by opening Settings>Software update>Download and install.
这个答案有帮助吗?
Well I will suggest you to scan your phone of junk file by using a good phone cleaner app and also delete the duplicate photos from you phone because we all have so many photos in are phone now day that also fill are phones memory that also mark are phones slow as well.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 100
总计 2,295
5条评论
My phone is very slow
由 العبادي ابو حامد العبادي 完成的
My phone is not working fastlu
=== Update (08/05/23) ===
It runs slow how to fix it
由 Uzumaki Naruto 完成的
@uzumakinar10212
Did you try what was suggested in the Most Helpful Answer below?
If you don't try things already suggested here and then reply if it worked or not then there may be other things that you can try but do them first!
由 jayeff 完成的
My phone slow idont khow
由 Mahendr 完成的
Tower slow problem could not connect
由 Bharath Ammu 完成的
