跳转到主内容
The Acer Aspire V5-571P-6815 laptop. This laptop has a 15.6" touchscreen.
2 个问题 查看全部
When I turn on the computer the screen stays black
Hi 👋🏼 I have an Acer aspire v5 running windows 8.1. And when I turn it on the screen shows nothing and it used to work with an HDMI cable but today it wasn’t working with HDMI EITHER
***''PLEASE HELP
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @aspirev5user
What is the full model number of the laptop?
Try starting the laptop in safe mode (scroll down to method #2 -Interrupt the normal boot process....) and check if there is a display.
If there is then there may be a video driver problem.
If you can't get into safe mode for whatever reason, try a power refresh in case it is a corrupted BIOS that is preventing a normal start.
Disconnect the charger if connected and then remove the battery from the laptop. (seen in 1st minute of video).
Press and hold the laptop's power On button for a full 30 seconds and then release.
Reinsert the battery and connect the charger and try turning the laptop on and check.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
DJGtech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 156
