跳转到主内容
加入维修社区 - 创建账户
The TI-84 Plus CSE is a graphing calculator by Texas Instruments released in 2014. It was the first TI-84 calculator to be equipped with a color screen.
Calculator won't charge - I think it's my port
My TI 84 plus c was working great for a long time, but recently I couldn't get it to turn on and the LED bar on the side would not light up when i plugged it in. I bought a new battery and charger from Amazon and installed it, but it still won't light up on the side. The battery had 25% charge in it so I could use it for a little bit - I need it for one more course.
I guess I'm wondering if there is any way I could tell that my port is broken or if there is anything I can play around with to get it to charge. My charger sits firmly-ish in the slot, it wiggles form side to side a bit if I play with it. Even when I move it around, the light doesn't even flash to show that I've got a charge even for a second. Any advice would be great!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Look into the port and see if anything looks wrong. Maybe you will have to replace the port, which would most likely require soldering to do.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marie M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 182
