跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
Ipad restart loop after replacing parts.
I have an Ipad Air and i have fitted a new battery and digitiser for it. I decided to do a test of the ipad to see if the new battery and digitiser worked and while the ipad does turn on, it turns off shortly if I drop it from a small height of around a cm or so. It does not do this if i apply pressure to where the LED connector and digitiser connector shield is, is this a result of improperly fitting something or do I simply need to apply the digitiser adhesive and seal the iPad once and for all since that might apply enough pressure across the entire LED? It also gets stuck in a restart loop from time to time.
I also understand that the Ipad can turn itself off if something comes out of its place leading me to believe that the battery might somehow also be improperly fitted?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Just because of the "turn off after a small bump" issue I'm going to say that the battery and/or logic board are not fully in place. Bumping as you describe would shift the electrode contact just enough to turn the unit off and on again. Your application of pressure near the location would also go with that.
这个答案有帮助吗?
得分 1
2条评论:
Would seem that leaving it fully untouched for a couple of minutes also sends it into a restart loop now, not sure what it could be
完成的
Might be heat-related, if it was off _just_ enough that contact was lost when heat expansion took place.
完成的
添加一条评论
添加你的答案
No Man 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 43
