Why is my phone on SOS only?
I cant call, it always says SOS only everytime i try to call somebody
Huawei SIM is 'SOS only', how to fix it? Follow me. You can do it.
1.Try turning on Flight Mode for 10 seconds and then turning it off. and see if the symptoms disappear.
2.Switch SIM to try another device. or put another sim in If the SIM card is broken, change it with the service provider. ... ( In the event that the device does not lock the SIM )
这个答案有帮助吗?
Sim kese in kren?
Tomorrow morning i was also facing the same problem but now my problem.
There are two reasons behind the problem
Why this problem happens in our smartphone.
This article will help you
https://okadtech.com/how-to-fix-sos-only...
If your problem is because of any hardware problems then you have to take you smartphone to any service centre but if it’s because of any software problem then you can just take help of this article and solve your problem.
这个答案有帮助吗?
Hi well you might be face some issue with your phones hardware or software. So for fix this issue you can check out this video it might be helpful for you: https://www.youtube.com/watch?v=TbDgVEla...
这个答案有帮助吗?
过去 24 小时: 10
过去 7 天: 33
过去 30 天: 124
总计 15,802
