跳转到主内容
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
I have an unreliable thunderbolt port, the second one works fine,
What could be the issue? The first one works then stops, then works then stops, I noticed some corrosion on the board while replacing the trackpad, but it's very confusing. None of them seem to even affect the tb3 controller.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
How about posting some pics so we too can see the corrosion 在已经存在的问题里加入图片
完成的
I wiped away the corrosion and it works fine now, haha! Quite interesting, there was corrosion shorting one of the very small chips on the board, almost looks like a tiny mosfet.
完成的
添加一条评论
1个答案
已选择的解决方案
You may need to replace the MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board that will require lifting the logic board out to give you access to the screws which hold the port assembly as you can see here
Replace one of the thunderbolt connector boards from the left or right side of your laptop.图片
产品
$14.99
这个答案有帮助吗?
得分 1
1条评论:
Wiped away the corrosion and it works now, but Dan's answer is the one that should work for basically everyone. <3 It seems like my problem was on the main board though, not the USB port board!
完成的
添加一条评论
添加你的答案
wkw030210 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 371
