I can’t remove screws from home button
I’m having trouble removing the home button screws, I’ve tried two different screwdrivers and they’re not budging. please help
Two two screws are just Philips #000. Assuming you're using the correct screwdriver and you haven't stripped the screws, a good way to get a tight screw loosened is to actually tighten it a tiny bit first. This "breaks" the seal that the screw may have with its matching thread, making it much easier to loosen and back ou.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 48
