跳转到主内容
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
113 个问题 查看全部
13-inch MacBook Pro 2020 will only charge from selective cable / brick
I have a 13" MacBook Pro 2020
MBP 13.3 SPG/8C CPU/8C GPU/8GB/256GB-USA
Product #MYD82LL/A
The MacBook will no longer charge from the stock USB cable and charging brick.
Thinking it might be a bad cable. I tried a different USB-C cable (Thunderbolt 3 Cable 40Gbps Supports 100W) and it worked the first time it was connected and would not work after that.
Thinking the power brick might be bad I tried using my Anker PowerPort II 49.5W USB C Charger with my other cable that had just worked but it still would not charge. Before giving up I tried charging it off of my Oculus Quest cable and power brick and it works every time from this. the other power bricks and cords work fine with other equipment but the MacBook will no longer charge from them.
Does anyone know why it is being so selective? I have tried to go back to the stock brick and cord multiple times and my other brick and cord multiple times and it will not charge from them. I'm worried that it's going to stop charging from the Oculus brick and cord at some point.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Did you try the other port? Sometimes one port gets worn and/or the ports logic gets damaged.
完成的
Thanks Dan, yes I did try both ports. they both work with the Oculus charger and neither works with the other bricks.
完成的
添加一条评论
2个答案
已选择的解决方案
At this point I think you'll need to get to an Apple Store or authorized Apple service center as your logic board needs repairs/replacing. This should be covered under warranty!
Make sure you bring the original charger and USB cable.
I'm suspecting the USB chargers dialog is not being understood by your systems power logic. In the days of old the charger was a dumb power source and the computer had a simple MOSFET switching logic (think older Unibody MacBooks) Today we have micro controllers in the chargers which have a dialog to the computer telling it what it is and the computer tells the charger what it needs. This dialog for some reason is not working correctly. I think the logic within the computer is messed up.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
After playing with it more today it looks like the first two usb cords I used went bad. not sure if the laptop is destroying them some how but I bought a new cord today and its working with the stock brick. I have never seen two cords go bad on the same day but I guess it happens. Thanks for the help
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jonathan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 156
