跳转到主内容
2021年10月发布的14英寸MacBook Pro的维修指南和拆解信息,该产品采用苹果设计的M1 Pro和M1 Max SoC,型号为A2442。
71 个问题 查看全部
Weird screen edge spot
Hi,
I just bought my first Macbook and as it`s great all over, I`ve noticed that on the top edge of the screen there are bright lines. Is it normal or should I be concerned? I`m thinking if it`s pay off the hustle to return it if there is a chance to get it again as (maybe) it`s not unusual.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@jakubkn - I see a white line along the rubber gasket where the screen and metal edge meet up. Is that what you are noting?
If it is does this looks like light leaking out or is it some adhesive that squeezed out?
完成的
@danj Yes. Unfortunately it`s neither of that. It`s visible with screen turned off. Tried microfibre cloth of course, but it is more like cut or brushed that black layer at very end.
完成的
添加一条评论
3个答案
If it bothers you I would make the effort to get it fixed (they would likely replace the display) if you just got it then they would likely exchange the system out. I don't think this is a widespread issue, to be safe I would open the packaging up at the store and make a good inspection.
这个答案有帮助吗?
得分 0
添加一条评论
I believe this is a manufacturing defect, the black paint behind the glass has been scuffed off maybe by production fixture.
A tiny amount of paint scuffing off may allow light reflected across the front glass to leak out the edges.
Ask Apple if they would offer exchange or repair. It is possible that they will refuse citing this is just a cosmetic issue.
If Apple won't fix it for free, in my opinion this tiny defect is not worth fixing, since you'll need to replace the whole display, maybe just paint it over using a black sharpie.
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
I have the same problem, did you manage to fix this?? Thanks, would really appreciate a reply please its driving me mad!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jakub K. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 38
总计 1,042
