iStat Pro Report - Rear Main Fan 0 rpm
iBook bottom has always been extra hot. Recently replaced battery and DC in board. Runs great, but needs a thermal blanket. Should I replace the fan, or is more troubleshooting needed first.
Good job and thanks for coming back to share solution.
Found an excellent app - G4FanControl 0.6.1. Resets threshold settings. iStat now shows 8200rpm. Much cooler too. carlstaff, Feb 1 @ 10:42 PM
This answer needs to be accepted or voted up.
N.
这个答案有帮助吗?
Do you hear the fan when you watch videos on youtube or when you do intensives jobs ? If no then replace the fan. Cheap repair.
这个答案有帮助吗?
AKA- Flash
Most likely that istat is just not compatible with your iBook..
Their website advises that it doesn't work with most PPC Machines..
这个答案有帮助吗?
I highly doubt that it's a false positive.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,625
2条评论
由 carlstaff 完成的
Hi- good job solving it yourself, can you please though put this comment as an Answer instead and them Accept it so we can see what worked? Thanks.
由 rab777hp 完成的
