跳转到主内容
Repair guides and support for the eighth generation of Ford F-Series trucks: the F-150, F-250, F-350, and F-Super Duty.
Why won't my ignition switch turn all the way off?
Why is my ignition switch not turning all the way off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Dear Harold in ignition switch also have steering wheel lock which not allow to key out of ignition until it's locked completely.
这个答案有帮助吗?
得分 0
添加一条评论
These switches are common failures, but tilt columns also suffer from binding in the column and the gear that the ignition switch turns. Attached below is my YouTube video on changing the turn signal switch, but it also shows how to remove the ignition assembly and how to take the steering column apart. With it apart you can inspect all the moving parts, lubricate the gear and ignition switch housing. Follow all my videos on repairs done to this 1991 F250 4x4 7.3l IDI on my channel @Caddyman and look for the dedicated Playlist to this vehicle.
https://youtu.be/ZKlkU0iOrw0?si=syoYhr_K...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harold Goodwin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 101
