跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
121 个问题 查看全部
Ram dont run at 3200
I had my ram run at 3200 suddenly my pc close and from that moment when i put my rams ay 3200 the computer didn't open and when it did the rams goes at 2133 any help ;
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Hi, it sounds like one of your modules or slots may be faulty i.e. clocking the wrong speed. Re-seating one module at a time and alternating slots may help you diagnose this possibility.
这个答案有帮助吗?
得分 3
2条评论:
I would also mention that if you need to enable XMP to get your RAM to run at 3200, that's still technically an overclock. Even if the profile to achieve it is an easy to enable switch, it could just be that one of your sticks is not capable of sustaining that anymore. I agree, trying to run the sticks one at a time, see if the issue continues to occur to try and narrow down which stick is the issue.
完成的
Don't forget, motherboards have preferred slots, so check your manual
完成的
添加一条评论
添加你的答案
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 189
