跳转到主内容
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Need to identify blown component on logic board.
After successfully replacing a failed HDD with SSD, reloading from TimeMachine, boot up and login, the last step was to attach new display adhesive and attach the display to the chassis. Starting up again, no display. Opened the system again and found a blown (really blown) component. I must have made some error attaching the display cable. One tech I talked with thought it was a fuse. I need to verify, identify, and determine the value of the fuse/component.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
iMac Logic Board - Something's blown - can I fix it?
这个答案有帮助吗?
得分 3
2条评论:
I'm adding a couple ILHB0805ER251V to my order from Digikey. Hold that thought .........
完成的
Exact part. At Digikey, 9 cents. Perfect.
完成的
添加一条评论
添加你的答案
Ken H 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 114
