跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
How to fix iPhone not connecting to wifi
I have a iPhone 6s plus that when I try to connect to wifi the button is grayed out I have reset the network setting and just all settings and I still cant get it to work I'm going to try and update it but i don't think it will work any other things i can do
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
the wifi chip needs replaced
这个答案有帮助吗?
得分 2
2条评论:
ok i will try this
完成的
@keith_themuscovyduck Remember you will have to unbind the Wi-Fi Address from the NAND if you replace it.
完成的
添加一条评论
If the setting is greyed out, more than likely this is a hardware issue. You can certainly try resetting the device, but in all likelihood, it will not make a difference. Either the chip needs to be replaced, or something in the WiFi circuitry has sustained damage or has gone bad.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
keith_themuscovyduck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 133
