跳转到主内容
加入维修社区 - 创建账户
第二代起亚 Cadenza 于 2016 年秋季发布,由彼得·希瑞尔 (Peter Schreyer) 重新设计。
How do I fix the seat belt ribbon?
Seat belt is not being pulled back in
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If its not pulling in at all I would think it needs to be replaced. The mechanism is a complex little part that can even have a small charge that fires with the air bag to tighten the belt a little.
When you pull the belt all they way out dose it make the typical seat belt noise? Then its just all out sitting there with zero tension?
I had a belt that would retract slow or only 90% of the way; I washed the belt in hot water to make it more flexible, that helped a lot.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Arslan Khan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 576
