跳转到主内容
The Honda Element was a compact crossover SUV based on a modified CR-V platform, manufactured in East Liberty, Ohio and offered in front-wheel and all-wheel drive formats
6 个问题 查看全部
Rear of vehicle is squeaky, help!
My 2007 Honda Element is very squeaky. It appears that the noise is coming from the rear wheels of the vehicle and happens when the car is turning and sometimes just driving down the road. I have taken it to my mechanic, and they looked it over. They said there is nothing wrong with it besides it needing to be lubed up. They said my brakes, bushings, etc. are all fine. They lubed it up and it is only slightly better. They told me that I will have to get them to do it every few months until it is saturated. They did not charge me for anything, which is good. There has to be something that none of us are seeing. Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi @retrogamernc ,
Just to eliminate the possibility. Check if the rear shock absorbers are OK.
At the rear of the car go to one corner of the car and push down hard and as far as you can on the body of the car and then release. Do this two or three times in a row, to set up a bouncing/rocking motion. When you stop, the car should bounce up, then settle back to the at-rest height. If the car bounces more than twice, you most likely need new shocks. Do this on both sides.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
John Toomey 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 44
总计 642
