跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
How to fix bootlooping
how to fix iPhone 6 s plus boot looping I have this iPhone 6s plus that has a good battery and is stuck boot looping I was using it and it just froze and then I turned it off and then once I did this it just rebooted and now has been like this for a couple of hrs how do I fix this problem also the phone does this when unpluged so the battery should be good plus i tried a new one and it did not work
things i have tried
new battery
updating it
what else should i do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It is hard to diagnose this problem over the internet. If this came across my desk here is what I would do. I know you have completed some of these steps.
·         Remove the logic board and install it in a known good housing including a known good screen and battery. (If it boots you know it’s a parts issue)
·         Take a diode measurement of the PP_VCC_MAIN line. (A partial short on the 6s plus can cause your issue)
·         Try an update.
·         Put some pressure on the CPU while booting.
·         Check the PP1V8 has correct voltage.
·         Replace the Tristar IC.
·         Check the logic eeprom.
·         Check Baseband PMU and CPU on the 6s plus if they are faulty it will produce your problem.
If the update you performed was successful with no errors I would be inclined to say that the NAND and CPU are okay but you would need to check the power rails on these in case there is a partial short.
这个答案有帮助吗?
得分 2
1条评论:
i found a crack in the logic board used a rubber band and that fixed it for a temporary use
完成的
添加一条评论
添加你的答案
keith_themuscovyduck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 176
