跳转到主内容
Released in 2017 the ASUS ROG Strix GL503VD is a high performance gaming laptop.
12 个问题 查看全部
Where do I get CPU replacement fan?
Hello,
I have an Asus ROG GL503GE laptop. Recently the CPU side fan has been making scary grinding noise. I have searched almost everywhere to get a replacement fan, I contacted Asus customer care. None could help me, even the customer care representative said the model was very old and they had no replacement fan :(
I badly need to get this fan fixed. Any idea which types of fan will it support? The CPU fan's part number was: FCN DFS2013121A0T, rated at 12V 1A.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @stackneverflow
If you want just the fan then search online for DFS2013121A0T to get results for suppliers that suit you best.
If you want the complete thermal module then try this one.
According to this supplier there are two thermal modules available.
The first is Asus part #13NR0080AP0101 and it seems to be unavailable, or at least I can't find one.
The second, linked above is for a GL503GE-1B (Asus part #13NR0082AP0301).
I don't know what the difference is but you may be able to check by comparing yours to the image in the link.
You could try searching for the Asus part numbers to see if you can find other suppliers as I didn't look too hard. ;-)
Update (05/05/2022)
@stackneverflow
Try gently peeling off the label from the centre of the fan and see if you can see a bearing. There may or may not be a cap over it I don't know
If you can see it apply 1-2 drops only of light machine oil (sewing machine oil perhaps) to the bearing and see if this stops the noise.
Do not apply more than this as you don't want it running everywhere.
Replace the label in position when finished
Here's a video that may help as it shows how to access the fans once you have removed the cover etc. The fan label can be seen at 13 seconds into the video when the fans have been turned over.
这个答案有帮助吗?
得分 2
1条评论:
Thank you for taking the time to look up. Unfortunately, I couldn't buy from any of the sources above (shipping cost is showing 200$+). I just need to replace the fan, but they are selling the whole heatsink
完成的
添加一条评论
添加你的答案
Anwarul Bashir Shuaib 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 326
