Samsung Galaxy A51 stuck on charging icon (lightning bolt)
I have a Samsung Galaxy A51 which is stuck on the charging icon (lightning bolt). It shows no battery percentage. I tried replacing the battery and charging port but the problem remains the same. There is no liquid damage inside the device. Is there something I haven't thought off? Or is it a main board issue? I also tried force restarting the device with the volume - and power button
If you have the 4g version have you tried replacing the flex cable from the charging port to the mainboard?
由 Daniel 完成的
Thanks for your reply, forgot to mention it but I already tried it with a new main flex cable. Also tried getting in recovery or download mode but that also doesn't work.
由 Koen Tuithof 完成的
I also have the A51 and the lightening bolt is there when the phone is showing 100% charged. It works all day on usually just one charge which I doi overnight with the phone turned off. I just switched out my charging cable to try to stay a step ahead but even with the old cable the phone was still charging to 100%.
由 Martha Gammino 完成的
I have the same problem my Samsung galaxy A51 stuck at 67% percent never progressive what should I do?
由 GMAR UP 完成的
I put my Samsung a 51 on the charge when I wake up tomorrow, the phone was power, off when I press the start button, the phone can’t that time I don’t know what the problem I think the phone is died
由 Farooq Ragwal 完成的
显示更多的2条评论
