跳转到主内容
加入维修社区 - 创建账户
宏碁 Aspire 系列笔记本电脑的维修指南和支持,适合家庭和企业使用。
Keyboard Malfunction: Escape key doesn't work
New Acer Aspire 722 laptop purchased, shortly after I noticed the "ESC" key does not work... Is there a way to reset the keyboard to correct the problem, or does the entire keyboard need to be replaced?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Reinstall the keyboard drivers possibly, but i doubt it's a software problem since it is new. You can always use a external keyboard if you want until you have time to send it in. But i wouldn't mess with anything hardware wise if it's under warranty.
这个答案有帮助吗?
得分 1
1条评论:
I have actually corrected this problem, it turns out this was a software issue... possibly some kind of advanced setting. Not exactly sure what caused it but a system restore did the trick.
完成的
添加一条评论
最有帮助的答案
If this is a new unit I would have the maker correct the problem and if necessary replace the keyboard under warranty.
这个答案有帮助吗?
得分 3
3条评论:
This option is my last resort, this is a new unit and under warranty however I cannot part with the laptop for quite some time.
完成的
I agree with rj713 that the laptop is under warranty and the manufacturer should and will resolve the problem. You seem reluctant to have it repaired by them. Here is a link to a virtual keyboard that you can click on with your mouse. Here is a link to a number of places selling the keyboard, in several different colors. I am not having any luck finding a service manual to give you the replacement procedure.
完成的
I know with apple if your iPhone is broken you can have apple send you a new one first by putting a hold on your credit card for x amount of money and when you get the new one you can send the old one back. Then if apple confirms that it is not caused from abuse then they won't charge you. Maybe some other manufactures have a similar program?
完成的
添加一条评论
添加你的答案
abeleko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 7,024
