跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
Face ID error after screen replacement with component swap
Hello,
I replaced the screen on my iPhone XR with an OEM screen from a donor device. I actually took the whole donor device except the logic board, and I swapped all the front camera assembly and ear piece components from the old screen to the new, so theoretically FaceID should be functioning, but it is not and I wonder if you fine folks could help me diagnose the issue.
It gives me the “move a little higher/lower” error. The odd thing is, the front camera works perfect, and portrait mode on the front camera works perfect as well. I thought this meant the dot matrix projector most be functioning, so I’m not sure what to look at when I take it apart. Flood Illuminator or IR camera?
Any points from those more experienced would be appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Mysteriously, there months later, I tried reenabling FaceID and it just worked fine. Maybe a software update was the cause? unsure. I have not opened the phone since, but now it works!
这个答案有帮助吗?
得分 0
1条评论:
Awesome, Zev! Sounds like you did everything right. From my reading it seems there are times when a reboot of the phone is needed to get Face ID working again, and others report that they had to remove the existing Face ID profile before it would work. It may indeed have been a software update that made the difference as well.
完成的
添加一条评论
添加你的答案
zev hoover 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 155
