跳转到主内容
加入维修社区 - 创建账户
This category covers the second-generation Chevrolet Aveo, also known as the Chevrolet Sonic, manufactured from 2011 to 2014.
Why is my engine stop after about five minutes
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
More information please. How is it dying? Gradually? Suddenly like you turned the key off? The more info the better. Any sounds, signs, or symptoms will help us help you.
完成的
Is the ECL (Engine Check Light) on?
完成的
I heard of a story one time of someone that put a marble in the gas tank of an ex-girlfriend. The car would start and run for a bit, then choke out when the marble got sucked onto the end of the fuel line pickup. Once the engine died, the marble would drop and the car would start and run fine.....till it happened again.
Anyway, agreed that more info is needed but if the fuel filter is getting clogged with trash from the tank, it would do just about the same thing just more gradually choking out instead of a dead stop. I had an S10 that did that till I replaced the fuel filter and fuel pump plus drained and flushed out the tank.
完成的
添加一条评论
1个答案
لديك مشكل في الحاسوب الاساسي
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
azhari alkagam 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 14
总计 434
