跳转到主内容
加入维修社区 - 创建账户
Samsung NP-R580-JBB2 笔记本电脑,搭载 500 GB 硬盘和 15.6 英寸显示屏,于 2010 年 10 月发布。
Not turning on or charging
My laptop had a grind sound for a week, now it just shutdown and it no longer turns on or charge
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @mr_logical ,
The grinding sound is not good and if it came from the HDD it shouldn't stop the laptop from charging unless it caused a problem on the motherboard.
Start by checking that the charger / charger cord is OK by ensuring that there is 19V DC available when measured at the charger plug.
Next would be to check if the laptop's DC-In jack is OK, (supplier example only to show the part).
Sometimes the centre pin of the jack breaks internally (where you can't see it) and this prevents the power from the charger either charging the battery or running the laptop. So it may be that the battery has gone flat because it couldn't be charged and the laptop shutdown because there was no power available from the battery or the charger.
Here's a video that shows how to dis-assemble the laptop so that the DC-In jack can be tested to see if it is OK.
If it is OK then you would need to do further testing as to why the motherboard isn't indicating that it is getting any power. You would need the motherboard schematics to do this.
这个答案有帮助吗?
得分 2
3条评论:
Thank you @jayeff I appreciate your help
完成的
@jayeff you are right, i just checked the charging cord, the is no power coming
完成的
Hi @mr_logical
Thanks for the update.
You would have to check if it is the charger or the charger cord that is faulty.
Either that or replace the charger (supplier example only)
Cheers
完成的
添加一条评论
添加你的答案
Emmanuel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 445
