Where can I get a replacement part
Hi,
So when tightening the steering wheel on to my table...
The bottom part snapped off
Logitechs support got no where
Heres a photo:
Hi @beanman56 ,
This may be your only option
这个答案有帮助吗?
:,C should I try epoxy or glue or taping it on?
I have some gorilla glue that’s really strong
You could try epoxy but check the product label to see if it is used for all plastics or not. For example JB Weld Plastic Weld epoxy does not stick to polyethylene, polypropylene and some other plastics.
So if thinking about an epoxy adhesive you may have to try a little bit first in an inconspicuous place to see if it sticks or not.
As best as I can find out Logitech is making a lot of their products from PCR plastic (Post Consumer Recycled) so goodness knows what type it is. Also read that a lot of polycarbonate PCR plastic is used in devices requiring a bit of strength e.g. laptop covers, printers, chargers etc which to my mind lines up a bit with your device, so maybe an epoxy would work
Not sure about gorilla glue as I've never used it .
A lot of glues aren't suitable for all the various types of plastics out there, only for some types. I've had cases where some didn't even stick or they seemed to melt the plastic.
You can only try
Good luck.
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 27
总计 525
