跳转到主内容
A 14.1 MP camera released in 2012. The Nikon Coolpix L310 support and repair information.
16 个问题 查看全部
battery/memory card slot cover is stuck
how to open the battery cover when you think the batteries are corroded ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did you review your owner's manual or review questions here for NK L310? Sometimes pressing down firmly on the battery cover before sliding the cover may help. A hard rap with a wooden or plastic handle with just enough force may break battery leakage creating the equivalent of instant glue bonding the cover to batteries. Any indication of battery leakage around the cover, apply some mineral/baby oil onto a Q-tip and gently swab around the cover perimeter may help loosen corrosion bonding the clover to the camera body. Use as little oil as possible, enough to allow it to work between the cover lines to seep into the dust seal. Let oil seep in then rap the cover a few times. Any excess oil can be absorbed with Q-tips or tissue. Hopefully, batteries aren't corroded but if the cover is removed to reveal corrosion, you may have to clean off corrosion on terminals after batteries are removed. De-Oxit is a product for cleaning battery corrosion on electrical contacts while promoting better connections.
完成的
添加一条评论
1个答案
Take qtip.rub around shut port.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Deborah Morawski 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 40
总计 308
