跳转到主内容
加入维修社区 - 创建账户
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
Top Screen wouldn't go all the way without clitching, Won't turn on.
My 3DS XL that I've had for 8.5 years started to glitch on the top screen when opened all the way, and you could only play it when it looked like a mini laptop. Now, it won't turn on, even after charging. I hope I won't have to replace the top screen, but I might just keep it as a piece of history.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Given that you stated the screen has artifacts when fully opened leads me to believe that the ribbon cable that from the bottom of the 3DS and the top screen has been damaged. It's routed through the hinge on the 3DS, which would explain why opening and closing the device would change things. Unfortunately, to fix this issue, you'd need to replace the entire top screen. This guide would show you how to replace the top screen. Speaking on the issue of the console not turning on, I can't give you a definitive answer. I've seen units that won't turn on if the device has enough screen damage, but it's a shot in the dark whether or not replacing the screen will fix it.
这个答案有帮助吗?
得分 1
1条评论:
Is there any way I can just replace the cables?
完成的
添加一条评论
添加你的答案
Cooper Thorne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 263
