跳转到主内容
Repair and disassembly information for the Logitech MX Master 2S wireless mouse. Released in 2017 and identified by model numbers M-R0066, 910-005131, 910-005139, 910-005839, or 910-005965.
6 个问题 查看全部
Sensor no longer picking up movement.
All other functions of the mouse work normally, it just will not pick up movement.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
1条评论
Ok this is weird - the same thing happened to me too, on the SAME DAY!!
完成的
添加一条评论
2个答案
最有帮助的答案
This happened to me last week on the same day as you posted your question, spooky!
To fix it I found this repair guide, which suggests that the gesture button can get stuck if it gets pressed... wrong.
I used this teardown guide to open the mouse up with an iOpener to soften the sticker adhesive and a metal spudger to peel it up, then broad tweezers to prevent tearing or grease from my fingers, I followed Steps 1-2. Then the first part of Step 3 to remove the black screws. I tested the button and its mechanism. Both seems to actuate fine, so I reattached it without tightening fully to give it a little wiggle room.
Once I reassembled the mouse and used the iOpener to soften the adhesive and smooth it back down the the metal spudger, it worked as good as new, if a little more crinkly on the bottom, which is undetectable in normal operation.
这个答案有帮助吗?
得分 7
3条评论:
I had the same problem, following these steps I solved it. Thank you!
完成的
works like charm
完成的
It helped me a lot! I just untightened the screws of gesture button twice, in first time it was also helpful, but after one hour the problem started again, after the second untightening is it good. Thank you a lot! My wife has a gold standard "new" mouse after that fix :)
完成的
添加一条评论
Well my friend this video might helpful for you.
https://www.youtube.com/watch?v=VbgN4Ywt...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brentleigh Ward 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 88
过去 30 天: 606
总计 2,441
