跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
My SSD will not show up on computer
I have a custom built PC that I built myself. I recently bought an extra 500GB of storage because I was running out on my other drive. When I connected it however it does not show up as a usable storage device. When I go deeper into the settings I can see that it is connected but I am not able to use/see it on the windows file explorer. I have tried several methods to fix it including getting a new cable however it still does not work. If anyone could help I would be grateful as I am tired of deleting everything that I don't constantly use just to free up space.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
10条评论:
Have you tried BIOs?
完成的
@nytryder26 yes I have and still couldn't find what was wrong
完成的
@orangebucket Who is it by and who did you buy it from?
完成的
Hi @orangebucket
Have you tried initializing the SSD in Windows, you didn't say?
完成的
yes i have but it does not show up there
完成的
显示更多的5条评论
添加一条评论
2个答案
Are you connecting ssd drive as a second drive externally like a ssd to usb adaptor? either way you need to partition the secondary drive and set a simple volume to it to be recognized by computer. If your drive is not hardware or water damaged it should work. You can search disk management for more info. hope that helps.
这个答案有帮助吗?
得分 0
添加一条评论
https://answers.microsoft.com/en-us/wind...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
OrangeBucket 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 511
